Aller au contenu principal
Dyson V6 Motorhead Motor Replacement
Ce dont vous avez besoin
  1. Dyson V6 Motorhead Motor Replacement, Collection Bin: étape 1, image 1 de 2 Dyson V6 Motorhead Motor Replacement, Collection Bin: étape 1, image 2 de 2
    • Pull down on the red release tab.
    • When the tab is fully engaged, the bottom of the bin should open.
  2. Dyson V6 Motorhead Motor Replacement: étape 2, image 1 de 2 Dyson V6 Motorhead Motor Replacement: étape 2, image 2 de 2
    • Pull down on the release tab a second time, this time the collection bin should release from the upper vacuum head.
  3. Dyson V6 Motorhead Motor Replacement: étape 3, image 1 de 3 Dyson V6 Motorhead Motor Replacement: étape 3, image 2 de 3 Dyson V6 Motorhead Motor Replacement: étape 3, image 3 de 3
    • Pull the collection bin away from the upper vacuum head.
  4. Dyson V6 Motorhead Motor Replacement, Motor: étape 4, image 1 de 1
    • Identify the two white components between the vacuum handle and the attached component.
  5. Dyson V6 Motorhead Motor Replacement: étape 5, image 1 de 2 Dyson V6 Motorhead Motor Replacement: étape 5, image 2 de 2
    • Insert each arm of the tweezer into each white component area and squeeze simultaneously to release the motor from the attached component.
  6. Dyson V6 Motorhead Motor Replacement: étape 6, image 1 de 2 Dyson V6 Motorhead Motor Replacement: étape 6, image 2 de 2
    • Detach the motor from the remaining motor head assembly.
10 autres ont terminé cette réparation.
Addie Hedge
Membre depuis le 01/24/17
710 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 22-6, Maness Winter 2017 Membre de l'équipe Cal Poly, Team 22-6, Maness Winter 2017
CPSU-MANESS-W17S22G6
4 membres
5 tutoriels rédigés
3 commentaires
really good can understand and not too technical
kelvin - Réponse
I am terrible at fixing things and this helped me put my vacuum back together after it fell and the motor detached from the handle. Thank you!!!
Chris Tadda - Réponse
Can't see the tweezer being inserted into the white tabs. Picture not clear. Could not dislodge motorhead from cannister bin. Show a clearer picture. Thanks
Hem - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 14
30 derniers jours : 59
Total : 18,815
