Introduction
Follow this guide to replace the head assembly on a EDCO Disk Grinder model 50200-HD.
This repair requires two people.
Ce dont vous avez besoin
Ensure the machine is unplugged.
Turn the power switch counterclockwise into the OFF position.
Use a 9/16 inch socket to remove the two bolts securing the weighted hood.
Use a 9/16 inch socket to loosen the bolts securing the motor mount.
Use a 5/32 inch hex wrench to loosen the set screw securing the sheave to the head assembly shaft.
Use a 7/32 inch hex key to remove the four flat screws securing the disk to the head assembly.
Use a dead blow hammer to hit the head assembly shaft straight down until it is flush with the upper bearing bracket, or as far as it will go.
Insert the new head assembly up into the bearing as far as you can by hand.
Use a dead blow hammer to knock the head assembly up into the machine until there is no play in the shaft spacer.
5 autres ont terminé cette réparation.
