Aller au contenu principal
Pour réparer ensemble - Je crée un compte
ESGE Zauberstab - Bamix motor replace
Ce dont vous avez besoin
    1. ESGE Zauberstab - Bamix motor replace, Remove top cover: étape 1, image 1 de 3 ESGE Zauberstab - Bamix motor replace, Remove top cover: étape 1, image 2 de 3 ESGE Zauberstab - Bamix motor replace, Remove top cover: étape 1, image 3 de 3
      Outil utilisé dans cette étape :
      iFixit Precision 4 mm Screwdriver Bit
      $2.99
      • Unplug the power cord and remove the cutter blade.
      • The top cover is fastened with two Torx TR10 security screws. These screws are different from normal Torx screws: they are equipped with a center pin. Use the right bit or screwdriver with center hole.
      • Remove two Torx TR10 screws.
      • Carefully lift off the cover. It is latched at the front.
      Demander à FixBot
      Ajouter un commentaire
    2. ESGE Zauberstab - Bamix motor replace: étape 2, image 1 de 3 ESGE Zauberstab - Bamix motor replace: étape 2, image 2 de 3 ESGE Zauberstab - Bamix motor replace: étape 2, image 3 de 3
      • This is what it looks like under the cover.
      • Slide out the two buttons and the small circuit board. The buttons are only snapped in.
      Demander à FixBot
    3. ESGE Zauberstab - Bamix motor replace: étape 3, image 1 de 2 ESGE Zauberstab - Bamix motor replace: étape 3, image 2 de 2
      • The handle is fastened with a Torx T8 machine screw and a Torx T8 plastic screw. You will need a long screwdriver.
      • Remove two Torx T8 screws.
      Demander à FixBot
    4. ESGE Zauberstab - Bamix motor replace: étape 4, image 1 de 3 ESGE Zauberstab - Bamix motor replace: étape 4, image 2 de 3 ESGE Zauberstab - Bamix motor replace: étape 4, image 3 de 3
      • On newer models, the handle looks slightly different, see picture 1.
      • Carefully press the two catches on the switch module down a little. Then pull the module inwards a little.
      • Carefully pull the switch module out of the device.
      • Unscrew the Torx T8 screw and the Torx T10 screw inside.
      Demander à FixBot
    5. ESGE Zauberstab - Bamix motor replace: étape 5, image 1 de 2 ESGE Zauberstab - Bamix motor replace: étape 5, image 2 de 2
      • Unclip the handle from one side.
      • Unthread the cable, the buttons and the board.
      • The motor ist exposed. However, it is not yet completely accessible, since the lower plastic housing part cannot yet be slid over the bell. The bell must first be removed.
      Demander à FixBot
    6. ESGE Zauberstab - Bamix motor replace: étape 6, image 1 de 3 ESGE Zauberstab - Bamix motor replace: étape 6, image 2 de 3 ESGE Zauberstab - Bamix motor replace: étape 6, image 3 de 3
      • First try If the bell can be unscrewed. It is fastened with a left-hand thread, so turn it in the "wrong direction", clockwise, to loosen it.
      • Pull on the knife to remove it
      • The bell sits probably quite tight, as it should not come loose during normal operation. When reassembling, glue it in place with a few drops of fluid threadlocker, if needed.
      • If it does not come off easily, then slide the lower plastic part towards the bell and clamp the motor in a vice. Do not tighten the vice very much, the motor is sensitive.
      • Use a long screwdriver as a lever between the bell and the shaft. Then carefully unscrew the bell. Reminder: the wrong way round, i.e. clockwise.
      • Pay attention to the washer between the shaft and the bell, do not lose it.
      Demander à FixBot
    7. ESGE Zauberstab - Bamix motor replace: étape 7, image 1 de 1
      • Pull off the lower case over the shaft.
      Demander à FixBot
    1. ESGE Zauberstab - Bamix motor replace, Motor replace: étape 8, image 1 de 2 ESGE Zauberstab - Bamix motor replace, Motor replace: étape 8, image 2 de 2
      • Using a Torx T15 screwdriver unscrew the two screws securing the flange of the shaft to the motor.
      • Seperate the flange including the shaft from the motor.
      Demander à FixBot
    2. ESGE Zauberstab - Bamix motor replace: étape 9, image 1 de 3 ESGE Zauberstab - Bamix motor replace: étape 9, image 2 de 3 ESGE Zauberstab - Bamix motor replace: étape 9, image 3 de 3
      • Desolder the red and the white wire. These wires are thin and delicate, don't break them.
      • The motor remains.
      Demander à FixBot
Merci à ces traducteurs :
de en
100%
VauWeh nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
VauWeh
Membre depuis le 10/19/15
339 386 Réputation
311 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 27
30 derniers jours : 81
Total : 2,714
