Introduction
This guide will show you how to replace the joysticks on your EasySMX ESM-9110.
Ce dont vous avez besoin
Use a Phillips #000 screwdriver to remove four 20 mm screws from the controller's faceplate.
Use a Phillips #000 screwdriver (a screwdriver bit extension may be needed) to remove the two 20 mm screws from the controllers faceplate.
Presque terminé !
