Introduction
Use this guide to replace the chain brake assembly in your Echo Chain Saw CS-4910 (2020).
The chain brake assembly is essential for safe operation. If it's not installed properly, it could fail to prevent serious injury.
Ce dont vous avez besoin
Make sure you have the ignition switch turned off before starting your repair.
Use your fingers to pull up and disconnect the spark plug boot.
Use a 13 mm wrench to loosen and remove the two nuts securing the sprocket guard.
Pull the sprocket guard straight off its two pegs and remove it.
Pull the saw chain away from the tip of the guide bar to unclip it.
Push the guide bar towards the back of the device to unclip the rest of the saw chain.
Pull the guide bar away from the device to separate the saw chain from the clutch drum.
Remove the guide bar and the saw chain.
Use a T25 Torx driver to remove the two 17 mm-long screws securing the bumper spike.
Pull the bumper spike away from the chassis and remove it.
Remove the two screws securing the inner guide plate:
Use a Phillips driver to remove the 8 mm-long screw.
Use a T25 Torx driver to remove the 33 mm-long screw.
Pull the inner guide plate straight off its two pegs and remove it.
Use a 2.5 mm hex key to remove the three 14 mm-long screws securing the brake cover.
Pull the brake cover straight off the chassis and remove it.
Make sure the chain brake is in the disengaged position before continuing.
Use a 4 mm hex key to remove the two screws securing the chain brake handle:
One 19 mm-long screw
One 23 mm-long screw
Rotate the chain brake handle towards the guide bar recess to unhook the brake lever.
Pull the handle away from the chassis to completely remove it.
Use a Phillips driver to remove the 8 mm-long screw securing the chain brake assembly.
While holding the spring with one hand, slowly push the brake lever out of its recess until the spring is fully extended.
Remove the chain brake assembly.
Use a flathead screwdriver to pry the collar out of its recess.
Remove the collar.
