Aller au contenu principal
Eclipse 180BL LCD Screen Cover Replacement
Ce dont vous avez besoin
  1. Eclipse 180BL LCD Screen Cover Replacement, LCD Screen Cover: étape 1, image 1 de 3 Eclipse 180BL LCD Screen Cover Replacement, LCD Screen Cover: étape 1, image 2 de 3 Eclipse 180BL LCD Screen Cover Replacement, LCD Screen Cover: étape 1, image 3 de 3
    • To start, remove the two screws located at the bottom of the device.
    • The two screws can be removed using the PH00 head located in the iFixit Repair ToolKit.
    • Both Screws are 1/8 inch in length.
    • Remove the case, and with the Spudger, apply force to the USB port to remove the inner component.
    • Be careful, as releasing the tension will cause all parts to become loose and separate.
  2. Eclipse 180BL LCD Screen Cover Replacement: étape 2, image 1 de 3 Eclipse 180BL LCD Screen Cover Replacement: étape 2, image 2 de 3 Eclipse 180BL LCD Screen Cover Replacement: étape 2, image 3 de 3
    • The LCD screen cover is placed into its slot after all the inner components are replaced.
    • Get the new screen cover, and carefully place in alignment with the outer shell.
    • Be sure that the screen fits perfectly, as dust getting in the screen will cause pixels to die.
Thomas Schwarz
Membre depuis le 09/07/15
499 Réputation
3 tutoriels rédigés
Équipe
USF Sarasota-Manatee, Team 1-2, Stewart Fall 2015 Membre de l'équipe USF Sarasota-Manatee, Team 1-2, Stewart Fall 2015
USFSM-STEWART-F15S1G2
5 membres
17 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 15
Total : 539
