Aller au contenu principal
Eclipse 180BL Touch Pad Replacement
Ce dont vous avez besoin
  1. Eclipse 180BL Touch Pad  Replacement, Touch Pad: étape 1, image 1 de 1
    • Remove the two screws at the bottom of the device.
    • The two screws can be removed using the PH00 head located in the iFixit Repair toolkit.
    • The two screws are 1/8 inch in length.
    • Remove the cover to reveal the internal component.
  2. Eclipse 180BL Touch Pad  Replacement: étape 2, image 1 de 3 Eclipse 180BL Touch Pad  Replacement: étape 2, image 2 de 3 Eclipse 180BL Touch Pad  Replacement: étape 2, image 3 de 3
    • Using the Spudger, forcefully push upward on the USB port of the device to remove the main component.
    • This will release the tension on the multiple parts. One of which will be the touch pad.
    • The touch pad can now be easily replaced.
    • The touch pad has a smaller center piece that must be replaced for proper usage of the device.
Thomas Schwarz
Membre depuis le 09/07/15
499 Réputation
3 tutoriels rédigés
Équipe
USF Sarasota-Manatee, Team 1-2, Stewart Fall 2015 Membre de l'équipe USF Sarasota-Manatee, Team 1-2, Stewart Fall 2015
USFSM-STEWART-F15S1G2
5 membres
17 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 14
Total : 669
