Aller au contenu principal
Eclipse 180G2 MP3 Video Player Battery Replacement
Ce dont vous avez besoin
  1. Eclipse 180G2 MP3 Video Player Battery Replacement, Outer Case: étape 1, image 1 de 2 Eclipse 180G2 MP3 Video Player Battery Replacement, Outer Case: étape 1, image 2 de 2
    • Remove the two screws on the bottom of the device with a Phillips head screwdriver.
    • Use a spudger to remove the plastic plate from the bottom of the player.
  2. Eclipse 180G2 MP3 Video Player Battery Replacement, Remove inner circuit from case shell: étape 2, image 1 de 3 Eclipse 180G2 MP3 Video Player Battery Replacement, Remove inner circuit from case shell: étape 2, image 2 de 3 Eclipse 180G2 MP3 Video Player Battery Replacement, Remove inner circuit from case shell: étape 2, image 3 de 3
    • Hold the device firmly between two fingers. Be sure you aren't holding down the top of the device; the circuit board will slide out of the shell through that end.
    • Use the spudger to push the USB port on the bottom of the device inward.
    • The plastic LCD cover and the key pad will now be free; they were held in place by the tension between the case and the internal circuit board.
  3. Eclipse 180G2 MP3 Video Player Battery Replacement, Finding the Battery: étape 3, image 1 de 1
    • The battery is the large packet-like component beneath where the buttons would be.
    • Gently lift the battery and move it off of the circuit board, allowing access to the wires.
  4. Eclipse 180G2 MP3 Video Player Battery Replacement, Separating the Battery: étape 4, image 1 de 1
    • Snip the wires using a wirecutter. Be careful not to nick the battery.
To reassemble your device, follow these instructions in reverse order after you've soldered the new battery.
7 autres ont terminé cette réparation.
James Walker
Membre depuis le 01/15/15
373 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 1-4, Tanski Winter 2015 Membre de l'équipe USF Tampa, Team 1-4, Tanski Winter 2015
USFT-TANSKI-W15S1G4
4 membres
5 tutoriels rédigés
7 commentaires
What kind of battery is it? And where do you get a new battery?
Tom - Réponse
Its a button cell battery like 1for a watch and Wal-Mart Walgreen riteaid should have it
JBreezy - Réponse
You should specify the battery type. The plastic wrap on the photo shows 180mAh capacity and it has to be rechargeable, unlikely to be lead-acid and therefore should not leak acid. Button cell batteries aren’t usually rechargeable so please explain exactly what battery type you used - manufacturer, model no. etc. Since you suggest cutting the wires, how do you reconnect to the new battery? The photo is inadequate to show how this is done. If the battery is a replaceable button cell, I would not expect it to be in an apparently sealed plastic bag.
Martin Willcocks - Réponse
https://www.alltechnerd.com/html5-video-...
Aayush - Réponse
It’s a 502025 Li-Po battery. Capacity doesn’t matter, but you can find them at 200mAh. The replacement batteries come with wires.
Electronics Overhaul - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 57
Total : 10,887
