Aller au contenu principal
Eclipse 180G2 MP3 Video Player speaker Replacement
Ce dont vous avez besoin
  1. Eclipse 180G2 MP3 Video Player speaker Replacement, Outer Case: étape 1, image 1 de 2 Eclipse 180G2 MP3 Video Player speaker Replacement, Outer Case: étape 1, image 2 de 2
    • Remove the two screws on the bottom of the device with a Phillips head screwdriver.
    • Use a spudger to remove the plastic plate from the bottom of the player.
  2. Eclipse 180G2 MP3 Video Player speaker Replacement, Remove inner circuit from case shell: étape 2, image 1 de 3 Eclipse 180G2 MP3 Video Player speaker Replacement, Remove inner circuit from case shell: étape 2, image 2 de 3 Eclipse 180G2 MP3 Video Player speaker Replacement, Remove inner circuit from case shell: étape 2, image 3 de 3
    • Hold the device firmly between two fingers. Be sure you aren't holding down the top of the device; the circuit board will slide out of the shell through that end.
    • Use the spudger to push the USB port on the bottom of the device inward.
    • The plastic LCD cover and the key pad will now be free; they were held in place by the tension between the case and the internal circuit board.
  3. Eclipse 180G2 MP3 Video Player speaker Replacement, Internal Speaker: étape 3, image 1 de 2 Eclipse 180G2 MP3 Video Player speaker Replacement, Internal Speaker: étape 3, image 2 de 2
    • Identify the speaker. Pull the speaker away from the device so that wires are exposed.
    • Using a wire cutter, sever the red and black cables that are connecting the speaker to the circuit board.
    • You will need to solder the new speaker wires to connect it to the device.
  • To reassemble your device after completion of replacement, follow these instructions in reverse order.
Jesse Minor
Membre depuis le 01/15/15
662 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 1-4, Tanski Winter 2015 Membre de l'équipe USF Tampa, Team 1-4, Tanski Winter 2015
USFT-TANSKI-W15S1G4
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 851
