Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Eclipse MTE28VGM Battery Replacement
Ce dont vous avez besoin
  1. Eclipse MTE28VGM Battery Replacement, Battery Replacement: étape 1, image 1 de 3 Eclipse MTE28VGM Battery Replacement, Battery Replacement: étape 1, image 2 de 3 Eclipse MTE28VGM Battery Replacement, Battery Replacement: étape 1, image 3 de 3
    • Using the screwdriver with the J00 bit, remove the two 4.8 mm Phillips screws.
    • Use caution when removing the screws as they can strip easily.
    Demander à FixBot
    Ajouter un commentaire
  2. Eclipse MTE28VGM Battery Replacement: étape 2, image 1 de 3 Eclipse MTE28VGM Battery Replacement: étape 2, image 2 de 3 Eclipse MTE28VGM Battery Replacement: étape 2, image 3 de 3
    • Using the small metal pry bar, remove the bottom plastic cover.
    • Using your thumb, press down on the home button and hold the metal casing. With your other hand hold the top plastic part of the device. At the same time slide the metal casing and the plastic casing apart.
    • On occasion the battery can become swollen and make this process difficult. You might need to use the spudger to push on the bottom components to assist in the separation.
    Demander à FixBot
  3. Eclipse MTE28VGM Battery Replacement: étape 3, image 1 de 3 Eclipse MTE28VGM Battery Replacement: étape 3, image 2 de 3 Eclipse MTE28VGM Battery Replacement: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    • Using the straight tweezers, remove the plastic coating on the wires.
    Demander à FixBot
  4. Eclipse MTE28VGM Battery Replacement: étape 4, image 1 de 3 Eclipse MTE28VGM Battery Replacement: étape 4, image 2 de 3 Eclipse MTE28VGM Battery Replacement: étape 4, image 3 de 3
    • Using the soldering guide, desolder the battery connections.
    • Soldering is a dangerous process, and caution needs to be taken to avoid injury.
    Demander à FixBot
Brendon Yates
Membre depuis le 09/29/16
309 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team 2-1, Harley Fall 2016 Membre de l'équipe IUPUI, Team 2-1, Harley Fall 2016
IUPUI-HARLEY-F16S2G1
4 membres
12 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 30
Total : 716
