Aller au contenu principal
Introduction
This guide is required when the camera is taking distorted photos and it has been determined that it is because of the plastic lens cover being scratched.
Pièces
Aucune pièce spécifiée.
  1. Using the screwdriver with the J00 bit, remove the two 4.8 mm Phillips  screws. Use caution when removing the screws as they can strip easily. Use caution when removing the screws as they can strip easily.
    • Using the screwdriver with the J00 bit, remove the two 4.8 mm Phillips screws.
    • Use caution when removing the screws as they can strip easily.
  2. Using the small metal pry bar, remove the bottom plastic cover. Using your thumb, press down on the home button and hold the metal casing.  With your other hand hold the top plastic part of the device.  At the same time slide the metal casing and the plastic casing apart. On occasion the battery can become swollen and make this process difficult.  You might need to use the spudger to push on the bottom components to assist in the separation.
    • Using the small metal pry bar, remove the bottom plastic cover.
    • Using your thumb, press down on the home button and hold the metal casing. With your other hand hold the top plastic part of the device. At the same time slide the metal casing and the plastic casing apart.
    • On occasion the battery can become swollen and make this process difficult. You might need to use the spudger to push on the bottom components to assist in the separation.
  3. Using the plastic spudger, pry the plastic lens cover off of the camera. Attach the replacement plastic lens cover to the camera.
    • Using the plastic spudger, pry the plastic lens cover off of the camera.
    • Attach the replacement plastic lens cover to the camera.
Tyler Hudgens
Membre depuis le 29/09/2016
288 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team 2-1, Harley Fall 2016 Membre de l'équipe IUPUI, Team 2-1, Harley Fall 2016
IUPUI-HARLEY-F16S2G1
4 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 126
