Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Eclipse MTE28VGM Toggle Button Replacement
Ce dont vous avez besoin
  1. Eclipse MTE28VGM Toggle Button Replacement, Toggle Button: étape 1, image 1 de 3 Eclipse MTE28VGM Toggle Button Replacement, Toggle Button: étape 1, image 2 de 3 Eclipse MTE28VGM Toggle Button Replacement, Toggle Button: étape 1, image 3 de 3
    • Using the screwdriver with the J00 bit, remove the two 4.8 mm Phillips screws.
    • Use caution when removing the screws as they can strip easily.
    Demander à FixBot
    Ajouter un commentaire
  2. Eclipse MTE28VGM Toggle Button Replacement: étape 2, image 1 de 3 Eclipse MTE28VGM Toggle Button Replacement: étape 2, image 2 de 3 Eclipse MTE28VGM Toggle Button Replacement: étape 2, image 3 de 3
    • Using the small metal pry bar, remove the bottom plastic cover.
    • Using your thumb, press down on the home button and hold the metal casing. With your other hand hold the top plastic part of the device. At the same time slide the metal casing and the plastic casing apart
    • On occasion the battery can become swollen and make this process difficult. You might need to use the spudger to push on the bottom components to assist in the separation.
    Demander à FixBot
  3. Eclipse MTE28VGM Toggle Button Replacement: étape 3, image 1 de 3 Eclipse MTE28VGM Toggle Button Replacement: étape 3, image 2 de 3 Eclipse MTE28VGM Toggle Button Replacement: étape 3, image 3 de 3
    • Using the screwdriver, remove the four 4.8 mm Phillips head J00 screws at each corner of the motherboard.
    • Remove the motherboard from the front plastic cover and screen. Replace the old motherboard with the new motherboard.
    Demander à FixBot
  4. Eclipse MTE28VGM Toggle Button Replacement: étape 4, image 1 de 3 Eclipse MTE28VGM Toggle Button Replacement: étape 4, image 2 de 3 Eclipse MTE28VGM Toggle Button Replacement: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    $3.99
    Demander à FixBot
  5. Eclipse MTE28VGM Toggle Button Replacement: étape 5, image 1 de 1
    • Using the angled tweezers, disconnect the toggle button.
    Demander à FixBot
Tyler Hudgens
Membre depuis le 09/29/16
288 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team 2-1, Harley Fall 2016 Membre de l'équipe IUPUI, Team 2-1, Harley Fall 2016
IUPUI-HARLEY-F16S2G1
4 membres
12 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 25
Total : 353
