Aller au contenu principal
Eco X Gear Battery Replacement
Ce dont vous avez besoin
  1. Eco X Gear Battery Replacement, Frame: étape 1, image 1 de 1
    • Disconnect any power source and/or turn off device.
  2. Eco X Gear Battery Replacement: étape 2, image 1 de 1
    • Remove the 15 rubber plugs from the cavities using needle nose pliers.
  3. Eco X Gear Battery Replacement: étape 3, image 1 de 1
    • Use a phillips head screwdriver to remove the fifteen 6.4mm screws.
  4. Eco X Gear Battery Replacement: étape 4, image 1 de 1
    • Carefully separate the two sections of the frame.
    • Wires still connect the two sections. Be cautious to avoid damaging the wires, terminals, and electronics.
  5. Eco X Gear Battery Replacement, Battery: étape 5, image 1 de 1
    • Disconnect the wiring to improve accessibility to the battery.
  6. Eco X Gear Battery Replacement: étape 6, image 1 de 2 Eco X Gear Battery Replacement: étape 6, image 2 de 2
    • Remove the two screws that hold that bracket, securing the battery in place.
  7. Eco X Gear Battery Replacement: étape 7, image 1 de 1
    • Disconnect the wires that hold the batteries down to the motherboard.
  8. Eco X Gear Battery Replacement: étape 8, image 1 de 1
    • Pry the battery from the frame using your hands or an opening pick.
  9. Eco X Gear Battery Replacement: étape 9, image 1 de 1
    • When removing and installing the battery, be cautious to not damage any of the surrounding electronics.
James Lipsett
Membre depuis le 03/20/17
625 Réputation
6 tutoriels rédigés
Équipe
UMass Dartmouth, Team S9-G3, Martin Spring 2017 Membre de l'équipe UMass Dartmouth, Team S9-G3, Martin Spring 2017
UMASSD-MARTIN-S17S9G3
2 membres
6 tutoriels rédigés
3 commentaires
Where to get the new battery?
James Chen - Réponse
Hello EcoXGear lovers, i just bought this battery from amazon yesterday and perfect fit with polarity you can get the battery here
https://www.amazon.com/gp/product/B08ZCQ...
partha - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 23
Total : 672
