Aller au contenu principal
Eco X Gear LED Display Replacement
Ce dont vous avez besoin
  1. Eco X Gear LED Display Replacement, Frame: étape 1, image 1 de 1
    • Disconnect any power source and/or turn off device.
  2. Eco X Gear LED Display Replacement: étape 2, image 1 de 1
    • Remove the 15 rubber plugs from the cavities using needle nose pliers.
  3. Eco X Gear LED Display Replacement: étape 3, image 1 de 1
    • Use a phillips head screwdriver to remove the fifteen 6.4mm screws.
  4. Eco X Gear LED Display Replacement: étape 4, image 1 de 1
    • Carefully separate the two sections of the frame.
    • Wires still connect the two sections. Be cautious to avoid damaging the wires, terminals, and electronics.
  5. Eco X Gear LED Display Replacement, LED Display: étape 5, image 1 de 1
    • Locate the terminals coming off of the backside of the LED lights. Cut the terminals to remove the light from the frame.
  6. Eco X Gear LED Display Replacement: étape 6, image 1 de 1
    • Insert the new LED light into the frame. Use the solder and soldering iron to reconnect the terminals to the new lights.
James Lipsett
Membre depuis le 03/20/17
625 Réputation
6 tutoriels rédigés
Équipe
UMass Dartmouth, Team S9-G3, Martin Spring 2017 Membre de l'équipe UMass Dartmouth, Team S9-G3, Martin Spring 2017
UMASSD-MARTIN-S17S9G3
2 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 11
Total : 138
