Aller au contenu principal
Ecovacs Deebot 900 Bottom Case Replacement
Ce dont vous avez besoin
  1. Ecovacs Deebot 900 Bottom Case Replacement, Battery: étape 1, image 1 de 1
    • Remove all the brushes from the Deebot.
  2. Ecovacs Deebot 900 Bottom Case Replacement: étape 2, image 1 de 1
    • Using a Phillips #0 screwdriver, remove the two 12.25 mm screws holding the battery cover in place.​
  3. Ecovacs Deebot 900 Bottom Case Replacement: étape 3, image 1 de 1
    • Remove the battery cover.
  4. Ecovacs Deebot 900 Bottom Case Replacement: étape 4, image 1 de 1
    • Using the two white straps on the sides of the battery, gently remove the battery. ​
    • Be careful not to rip out the battery cable.
  5. Ecovacs Deebot 900 Bottom Case Replacement: étape 5, image 1 de 1
    • Carefully disconnect the battery cable by pulling near the connector at the bottom of the battery compartment.
  6. Ecovacs Deebot 900 Bottom Case Replacement, Front Bumper: étape 6, image 1 de 2 Ecovacs Deebot 900 Bottom Case Replacement, Front Bumper: étape 6, image 2 de 2
    • Using a Phillips #00 screwdriver, remove the eight screws on the bottom edge of the bumper. ​
  7. Ecovacs Deebot 900 Bottom Case Replacement: étape 7, image 1 de 1
    • Remove the black strip on the bottom of the bumper.
  8. Ecovacs Deebot 900 Bottom Case Replacement: étape 8, image 1 de 2 Ecovacs Deebot 900 Bottom Case Replacement: étape 8, image 2 de 2
    • Carefully lift up the bumper untill it pops out of place.​
  9. Ecovacs Deebot 900 Bottom Case Replacement: étape 9, image 1 de 2 Ecovacs Deebot 900 Bottom Case Replacement: étape 9, image 2 de 2
    • Disconnect the two cables connecting the bumper to the body of the Deebot.
    • Remove the front bumper from the device.
  10. Ecovacs Deebot 900 Bottom Case Replacement, Bottom Case: étape 10, image 1 de 2 Ecovacs Deebot 900 Bottom Case Replacement, Bottom Case: étape 10, image 2 de 2
    • Using a Phillips #00 screwdriver, take out the six screws around the perimeter of the bottom case.
  11. Ecovacs Deebot 900 Bottom Case Replacement: étape 11, image 1 de 2 Ecovacs Deebot 900 Bottom Case Replacement: étape 11, image 2 de 2
    • Insert a Jimmy into the seam and work all the way around the robot.
    • Disconnect the two cables and remove the bottom case from the device.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 35
Total : 2,313
