Aller au contenu principal
Ecovacs Deebot 900 Front Bumper Replacement
Ce dont vous avez besoin
  1. Ecovacs Deebot 900 Front Bumper Replacement, Battery: étape 1, image 1 de 1
    • Remove all the brushes from the Deebot.
  2. Ecovacs Deebot 900 Front Bumper Replacement: étape 2, image 1 de 1
    • Using a Phillips #0 screwdriver, remove the two 12.25 mm screws holding the battery cover in place.​
  3. Ecovacs Deebot 900 Front Bumper Replacement: étape 3, image 1 de 1
    • Remove the battery cover.
  4. Ecovacs Deebot 900 Front Bumper Replacement: étape 4, image 1 de 1
    • Using the two white straps on the sides of the battery, gently remove the battery. ​
    • Be careful not to rip out the battery cable.
  5. Ecovacs Deebot 900 Front Bumper Replacement: étape 5, image 1 de 1
    • Carefully disconnect the battery cable by pulling near the connector at the bottom of the battery compartment.
  6. Ecovacs Deebot 900 Front Bumper Replacement, Front Bumper: étape 6, image 1 de 2 Ecovacs Deebot 900 Front Bumper Replacement, Front Bumper: étape 6, image 2 de 2
    • Using a Phillips #00 screwdriver, remove the eight screws on the bottom edge of the bumper. ​
  7. Ecovacs Deebot 900 Front Bumper Replacement: étape 7, image 1 de 1
    • Remove the black strip on the bottom of the bumper.
  8. Ecovacs Deebot 900 Front Bumper Replacement: étape 8, image 1 de 2 Ecovacs Deebot 900 Front Bumper Replacement: étape 8, image 2 de 2
    • Carefully lift up the bumper untill it pops out of place.​
  9. Ecovacs Deebot 900 Front Bumper Replacement: étape 9, image 1 de 2 Ecovacs Deebot 900 Front Bumper Replacement: étape 9, image 2 de 2
    • Disconnect the two cables connecting the bumper to the body of the Deebot.
    • Remove the front bumper from the device.
Un commentaire
Where may I buy the front bumper assembly? I'm trying to replace one for a deebot 901 but the mfg tells me they don't see the part directly.
Chris Khacherian - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 55
30 derniers jours : 233
Total : 9,863
