Aller au contenu principal
Ecovacs Deebot 900 Motherboard Replacement
Ce dont vous avez besoin
  1. Ecovacs Deebot 900 Motherboard Replacement, Front Bumper: étape 1, image 1 de 2 Ecovacs Deebot 900 Motherboard Replacement, Front Bumper: étape 1, image 2 de 2
    • Using a Phillips #00 screwdriver, remove the eight screws on the bottom edge of the bumper. ​
  2. Ecovacs Deebot 900 Motherboard Replacement: étape 2, image 1 de 1
    • Remove the black strip on the bottom of the bumper.
  3. Ecovacs Deebot 900 Motherboard Replacement: étape 3, image 1 de 2 Ecovacs Deebot 900 Motherboard Replacement: étape 3, image 2 de 2
    • Carefully lift up the bumper untill it pops out of place.​
  4. Ecovacs Deebot 900 Motherboard Replacement: étape 4, image 1 de 2 Ecovacs Deebot 900 Motherboard Replacement: étape 4, image 2 de 2
    • Disconnect the two cables connecting the bumper to the body of the Deebot.
    • Remove the front bumper from the device.
  5. Ecovacs Deebot 900 Motherboard Replacement, Bottom Case: étape 5, image 1 de 2 Ecovacs Deebot 900 Motherboard Replacement, Bottom Case: étape 5, image 2 de 2
    • Using a Phillips #00 screwdriver, take out the six screws around the perimeter of the bottom case.
  6. Ecovacs Deebot 900 Motherboard Replacement: étape 6, image 1 de 2 Ecovacs Deebot 900 Motherboard Replacement: étape 6, image 2 de 2
    • Insert a Jimmy into the seam and work all the way around the robot.
    • Disconnect the two cables and remove the bottom case from the device.
  7. Ecovacs Deebot 900 Motherboard Replacement, Motherboard: étape 7, image 1 de 1
    • Using a Phillips #00 screwdriver, remove the two black screws holding the motherboard in place.​
  8. Ecovacs Deebot 900 Motherboard Replacement: étape 8, image 1 de 1
    • Carefully remove the ribbon cables connected to the top of motherboard.
    • Keep track of where the cables connect to the motherboard.
  9. Ecovacs Deebot 900 Motherboard Replacement: étape 9, image 1 de 1
    • Remove the last three ribbon cables on the underside of the motherboard.​
  10. Ecovacs Deebot 900 Motherboard Replacement: étape 10, image 1 de 1
    • Lift the motherboard out of the Deebot and remove it from the device.
4 autres ont terminé cette réparation.
2 commentaires
Any suggestions on purchase options?
Curtis Tyler - Réponse
vakum ozmo 900,hidup terus mati,lampu led juga mati,switch masih posisi on
markus arif - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 26
30 derniers jours : 166
Total : 7,241
