Introduction
The Ecovacs Deebot 900 is an autonomous vacuuming robot. If the vacuum motor is not working, the Deebot will not pick up debris and will be unable to clean. Use this guide to replace the vacuum motor of your Ecovacs Deebot 900.
Ce dont vous avez besoin
Using a Phillips #00 screwdriver, remove the eight screws on the bottom edge of the bumper.
Using a Phillips #00 screwdriver, take out the six screws around the perimeter of the bottom case.
Using the Phillips #00 screwdriver, remove the three screws around the laser unit.
5 autres ont terminé cette réparation.
Un commentaire
Where can you find a replacement vacuum motor for the zoom 930?
