Aller au contenu principal
Edwin the Duck Motherboard Replacement
Ce dont vous avez besoin
  1. Edwin the Duck Motherboard Replacement, Motherboard: étape 1, image 1 de 2 Edwin the Duck Motherboard Replacement, Motherboard: étape 1, image 2 de 2
    • Unscrew the four 9mm screws with a T8 screwdriver bit
    • Remove the back plate off
  2. Edwin the Duck Motherboard Replacement: étape 2, image 1 de 2 Edwin the Duck Motherboard Replacement: étape 2, image 2 de 2
    • Carefully take off the rubber skin.
    • Be patient and don't rush. You don't want to rip or damage the rubber skin resulting in losing the waterproof cover.
  3. Edwin the Duck Motherboard Replacement: étape 3, image 1 de 1
    • Using the J1 screwdriver bit, unscrew all six 9 mm screws that run along the border.
  4. Edwin the Duck Motherboard Replacement: étape 4, image 1 de 2 Edwin the Duck Motherboard Replacement: étape 4, image 2 de 2
    • Use the plastic opening tool to open the inside of the duck.
    • Be very careful when splitting the two halves apart. There are wires connecting to both sides. Remember to open slowly.
  5. Edwin the Duck Motherboard Replacement: étape 5, image 1 de 2 Edwin the Duck Motherboard Replacement: étape 5, image 2 de 2
    • Using the plastic opening tool pull up the black tab up until it stops.
    • Be careful not to pull up the black tab too far up, otherwise the cable won't be secure anymore.
    • Pull up the white cable tab, up slowly
  6. Edwin the Duck Motherboard Replacement: étape 6, image 1 de 1
    • Use the J1 screwdriver bit to unscrew all four 9 mm screws attached to the motherboard.
  7. Edwin the Duck Motherboard Replacement: étape 7, image 1 de 1
    • Remove the top connector as you see in the picture.
    • Replace the new motherboard and you are finished.
Caleb Kim
Membre depuis le 10/18/17
143 Réputation
1 tutoriel rédigé
Équipe
UW Tacoma, Team S1-G4, Rose Fall 2017 Membre de l'équipe UW Tacoma, Team S1-G4, Rose Fall 2017
UWT-ROSE-F17S1G4
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 7
30 derniers jours : 15
Total : 407
