Aller au contenu principal
Edwin the Duck Rubber Gasket Seal Replacement
Ce dont vous avez besoin
  1. Edwin the Duck Rubber Gasket Seal Replacement, Rubber Gasket Seal: étape 1, image 1 de 2 Edwin the Duck Rubber Gasket Seal Replacement, Rubber Gasket Seal: étape 1, image 2 de 2
    • Unscrew the four 9mm screws with aT8 bit
    • Take the back plate off
  2. Edwin the Duck Rubber Gasket Seal Replacement: étape 2, image 1 de 2 Edwin the Duck Rubber Gasket Seal Replacement: étape 2, image 2 de 2
    • Carefully take off the rubber skin.
    • Be patient and don't rush. You don't want to rip or damage the rubber skin otherwise you will lose the waterproof cover.
  3. Edwin the Duck Rubber Gasket Seal Replacement: étape 3, image 1 de 1
    • Using the J1 bit, unscrew all six 9 mm screws around the border.
  4. Edwin the Duck Rubber Gasket Seal Replacement: étape 4, image 1 de 2 Edwin the Duck Rubber Gasket Seal Replacement: étape 4, image 2 de 2
    • Use the plastic opening tool to open the inside of the duck.
    • Be very careful when splitting the two halves apart. There are wires connecting to both sides. So open it very slowly.
  5. Edwin the Duck Rubber Gasket Seal Replacement: étape 5, image 1 de 2 Edwin the Duck Rubber Gasket Seal Replacement: étape 5, image 2 de 2
    • Remove the rubber gasket
  6. Edwin the Duck Rubber Gasket Seal Replacement: étape 6, image 1 de 1
    • Insert your new rubber gasket in and use the plastic opening tool to push the rubber gasket into it's slot
Nadia Dobrogorskaya
Membre depuis le 10/18/17
131 Réputation
1 tutoriel rédigé
Équipe
UW Tacoma, Team S1-G4, Rose Fall 2017 Membre de l'équipe UW Tacoma, Team S1-G4, Rose Fall 2017
UWT-ROSE-F17S1G4
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 348
