Aller au contenu principal
Eightarc Fusion Headphone Jack Replacement
Ce dont vous avez besoin
  1. Eightarc Fusion Headphone Jack Replacement, Headphone Jack: étape 1, image 1 de 2 Eightarc Fusion Headphone Jack Replacement, Headphone Jack: étape 1, image 2 de 2
    • Because of the protruding joystick on the top of the controller, make sure to work on a soft surface or prop the controller up to avoid stress on the joystick.
    • Place the controller face down (buttons and joystick down).
    • Use a Phillips Head #1 screwdriver to remove the eight 9.65mm screws located on the felt and metal backplate.
    • Do not confuse the four screws in the rubber feet with the eight screws in the felt. The screws in the feet do not need to be removed.
  2. Eightarc Fusion Headphone Jack Replacement: étape 2, image 1 de 1
    • Open the door for the cord storage compartment on the right side of the device.
    • Reach under the panel and push upwards on the back panel. Lift it up and remove it from the device.
  3. Eightarc Fusion Headphone Jack Replacement: étape 3, image 1 de 2 Eightarc Fusion Headphone Jack Replacement: étape 3, image 2 de 2
    • Grasp the white plug connecting the wires to the headphone jack, and pull gently upwards.
  4. Eightarc Fusion Headphone Jack Replacement: étape 4, image 1 de 1
    • Using a Phillips head #1 screwdriver, remove the two washer head screws from the headphone jack.
  5. Eightarc Fusion Headphone Jack Replacement: étape 5, image 1 de 2 Eightarc Fusion Headphone Jack Replacement: étape 5, image 2 de 2
    • Gently wiggle the headphone jack left and right, pulling it towards you until it slides out of the hole in the enclosure.
Christopher
Membre depuis le 01/29/15
133 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 17-35, Amido Winter 2015 Membre de l'équipe Cal Poly, Team 17-35, Amido Winter 2015
CPSU-AMIDO-W15S17G35
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 8
Total : 243
