Introduction
Follow this guide to replace or remove the 75’ cable on your Electric Eel 75' Drain Cleaner Z5K12IC75AF.
Ce dont vous avez besoin
Twist the guide spring counter-clockwise to unscrew it from the auto-feeder.
Remove the guide spring.
Unscrew the tension knob to loosen the tension spring in the top feeder assembly.
Set the feeder adjustment knob in the neutral position, in between the "FWD" and "REV" positions.
Grab the end of the cable and pull to begin removing the cable from the drum.
Use a flat-head screwdriver to remove the screw on the rear face of the drum that secures the cable anchor.
Pull the rest of the cable out of the drum through the auto-feeder to remove it.
2 autres ont terminé cette réparation.
