Introduction
One of the common problems with electric clothes dryers is a broken drive belt. It's quite easy to replace one: it will only cost you $15-$20 for the part and about 1 hour of your life
Ce dont vous avez besoin
There are many brands of electric dryers out there, but fortunately their construction follows just a few basic designs. The one I'm describing is a 20 year old Canadian Eaton model, but some of the inexpensive models sold today have the same construction.
A good indicator that you are dealing with a similar model is the presence of three screws at the end of the drum, which you can see after opening the appliance door. In these appliances the drum is held in place by the axis connected by the three screws you can see in the picture and the friction pads at the front panel of the dryer.
The first thing you will want to do is reach behind the dryer and unplug it from the electric outlet.
If the belt is not yet completely broken, you will need to disengage it from the motor an the tensioner. To do that, unscrew the service door at the back.
Inside the door you will see the drive belt, wrapped around the motor pulley and the tensioner. Reach inside the appliance, push down on the tensioner lever, and disengage the belt. Be careful not to cut yourself: there are sharp metal edges all around.
5 autres ont terminé cette réparation.
2 commentaires
Update from previous comment - for fitting the new belt https://www.youtube.com/watch?v=4M1x0luY...
I have GE Profile Washer and Dryer which have always had problems. Lately, the dryer takes even LONGER and I decided to clean everything I could reach, after unplugging dryer. The front lint trap is so narrow that even a dryer brush won’t reach all the way to where it curves back. So I unscrewed the 3 screws on the face plate of the drum cover, removed it and carefully cleaned all the debris and dirt. When replacing it it felt out of ‘round’ like there is a right and wrong screw for each position, but I was able to screw all 3 in tightly. When dryer started it began making loud scraping and dragging noise, worse in one direction. after a few minutes it turns off. If I leave it off for several minutes I can start it again, and the same loud noise occurs. It isn’t shutting off, but stopping. I tried moving the screw position and the plate sort off ‘snapped’ into position but the same noise occurred.
terre - Réponse
