Aller au contenu principal
Electrohome EAAC475 Button Replacement
Ce dont vous avez besoin
  1. Electrohome EAAC475 Button Replacement, Battery: étape 1, image 1 de 2 Electrohome EAAC475 Button Replacement, Battery: étape 1, image 2 de 2
    • Remove the 10 mm Phillips #1 screw from the battery cover.
    • Remove the battery cover.
  2. Electrohome EAAC475 Button Replacement: étape 2, image 1 de 1
    • Remove the flat lithium battery.
  3. Electrohome EAAC475 Button Replacement, Buttons: étape 3, image 1 de 2 Electrohome EAAC475 Button Replacement, Buttons: étape 3, image 2 de 2
    • Disconnect the radio from all power sources.
    • Remove the two 10 mm Phillips #1 screws from the bottom of the device.
    • Remove two 10 mm Phillips #1 screws from the back side of the device.
  4. Electrohome EAAC475 Button Replacement: étape 4, image 1 de 3 Electrohome EAAC475 Button Replacement: étape 4, image 2 de 3 Electrohome EAAC475 Button Replacement: étape 4, image 3 de 3
    • Carefully and slowly pull the lower case away from the rest of the device.
    • Do not completely separate the lower case. There are several wires connecting the two halves of the device.
    • Flip the device over to access the button assembly.
    • Slowly remove the button contact board from the assembly.
  5. Electrohome EAAC475 Button Replacement: étape 5, image 1 de 2 Electrohome EAAC475 Button Replacement: étape 5, image 2 de 2
    • Remove the two 7 mm Phillips # 1 screws holding the buttons.
    • Remove the plastic buttons.
Sohail Khatri
Membre depuis le 02/16/16
201 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team 2-1, Harley Spring 2016 Membre de l'équipe IUPUI, Team 2-1, Harley Spring 2016
IUPUI-HARLEY-S16S2G1
4 membres
6 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 11
Total : 347
