Aller au contenu principal
Electrohome EAAC475 Projector Lens Replacement
Ce dont vous avez besoin
  1. Electrohome EAAC475 Projector Lens Replacement, Battery: étape 1, image 1 de 2 Electrohome EAAC475 Projector Lens Replacement, Battery: étape 1, image 2 de 2
    • Remove the 10 mm Phillips #1 screw from the battery cover.
    • Remove the battery cover.
  2. Electrohome EAAC475 Projector Lens Replacement: étape 2, image 1 de 1
    • Remove the flat lithium battery.
  3. Electrohome EAAC475 Projector Lens Replacement, Projector Lens: étape 3, image 1 de 1
    • Slowly and carefully move one side away from another without detaching anything on the device.
  4. Electrohome EAAC475 Projector Lens Replacement: étape 4, image 1 de 1
    • Detach the projector.
  5. Electrohome EAAC475 Projector Lens Replacement: étape 5, image 1 de 2 Electrohome EAAC475 Projector Lens Replacement: étape 5, image 2 de 2
    • Unplug the projector's connector from the circuit board.
  6. Electrohome EAAC475 Projector Lens Replacement: étape 6, image 1 de 1
    • Take off the rubber ring.
  7. Electrohome EAAC475 Projector Lens Replacement: étape 7, image 1 de 3 Electrohome EAAC475 Projector Lens Replacement: étape 7, image 2 de 3 Electrohome EAAC475 Projector Lens Replacement: étape 7, image 3 de 3
    • Using a metal spudger, pry into the crease until it separates enough to slip the spudger between the pieces.
    • Slide the tool along the crease to separate.
  8. Electrohome EAAC475 Projector Lens Replacement: étape 8, image 1 de 1
    • Take the lens out of the projector.
  9. Electrohome EAAC475 Projector Lens Replacement: étape 9, image 1 de 1
    • Separate the lens and the gear by unscrewing the gear.
Sterling Fulk
Membre depuis le 02/16/16
264 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team 2-1, Harley Spring 2016 Membre de l'équipe IUPUI, Team 2-1, Harley Spring 2016
IUPUI-HARLEY-S16S2G1
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 367
