Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Elegoo Mars 3 Limit Switch Replacement
Ce dont vous avez besoin
    1. Elegoo Mars 3 Limit Switch Replacement, Remove the back screws: étape 1, image 1 de 1
      • Remove 6 screws.
      • 12.5mm self tapping screws with 2.0mm hex socket head
      Demander à FixBot
      Ajouter un commentaire
    2. Elegoo Mars 3 Limit Switch Replacement, Remove the back lid: étape 2, image 1 de 2 Elegoo Mars 3 Limit Switch Replacement, Remove the back lid: étape 2, image 2 de 2
      • Use a small flat-headed screwdriver, spudger, or similar to pry open the lid enough to be able to get a grip of it and pull straight back and then fold down.
      • The back of the lid has a PCB with cables connecting it to the motherboard inside the unit. While not particularly fragile, do take care so you do not damage the connectors.
      Demander à FixBot
    3. Elegoo Mars 3 Limit Switch Replacement, Unplug the cable for the limit switch: étape 3, image 1 de 1
      • In my case the replacement limit switch was delivered already connected to a cable. If you are only replacing the actual switch you can skip this step and instead unplug the opposing end on the switch itself later..
      • Remove the limit switch cable connector in the bottom right corner by pulling it straight out.
      • Be sure to pull the connector, and not the cables!
      Demander à FixBot
    4. Elegoo Mars 3 Limit Switch Replacement: étape 4, image 1 de 3 Elegoo Mars 3 Limit Switch Replacement: étape 4, image 2 de 3 Elegoo Mars 3 Limit Switch Replacement: étape 4, image 3 de 3
      • Remove the two screws securing the limit switch.
      • M4x7.5mm socket screw with 2.5mm hex socket head
      • Hold the limit switch in the lower end and pull it downwards.
      Demander à FixBot
Konrad Skeri Ekblad
Membre depuis le 12/10/17
550 Réputation
3 tutoriels rédigés
2 commentaires de tutoriel
I've looked everywhere and can't seem to find a place to buy a replacement limit switch. Any suggestions?
johnathan cuda - Réponse Partager
I got my replacement directly from Elegoo support. Send them an email, they are very helpful.
Konrad Skeri Ekblad - Réponse Partager
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 51
Total : 2,223
