Aller au contenu principal
Eluktronics N850HK SSD Replacement
Ce dont vous avez besoin
  1. Eluktronics N850HK SSD Replacement, SSD: étape 1, image 1 de 3 Eluktronics N850HK SSD Replacement, SSD: étape 1, image 2 de 3 Eluktronics N850HK SSD Replacement, SSD: étape 1, image 3 de 3
    • Push both switch locks inward to unlock the battery from the bottom panel.
    • The switch on the left must be held in place.
    • Remove the battery from the back of the laptop.
  2. Eluktronics N850HK SSD Replacement: étape 2, image 1 de 2 Eluktronics N850HK SSD Replacement: étape 2, image 2 de 2
    • Use a Phillips #00 screwdriver to remove the twelve 4 mm screws from the bottom panel of the laptop.
  3. Eluktronics N850HK SSD Replacement: étape 3, image 1 de 2 Eluktronics N850HK SSD Replacement: étape 3, image 2 de 2
    • Use a Phillips #00 screwdriver to remove the four 3 mm screws located under where the battery usually rests.
    • Do not remove the two additional screws near the bottom screw. These are connected to the motherboard and do not need to be removed.
  4. Eluktronics N850HK SSD Replacement: étape 4, image 1 de 2 Eluktronics N850HK SSD Replacement: étape 4, image 2 de 2
    • Lift the back case off and identify the SSD in the lower right corner.
    • Although the chances of damage are low, it is important to be aware of static electricity in your surroundings when working a computer motherboard. Ground yourself or use an anti-static wrist strap.
  5. Eluktronics N850HK SSD Replacement: étape 5, image 1 de 3 Eluktronics N850HK SSD Replacement: étape 5, image 2 de 3 Eluktronics N850HK SSD Replacement: étape 5, image 3 de 3
    • Use a Phillips #00 screwdriver to remove 3 mm screw securing the SSD.
    • The SSD will naturally lift by a few millimeters.
    • Carefully slide the SSD from the M.2 slot.
  6. Eluktronics N850HK SSD Replacement: étape 6, image 1 de 3 Eluktronics N850HK SSD Replacement: étape 6, image 2 de 3 Eluktronics N850HK SSD Replacement: étape 6, image 3 de 3
    • Use the ridges on the right side to align the SSD properly.
    • Slide the new SSD into the M.2 mounting slot.
    • Use the Phillips #00 screwdriver to replace the 3 mm screw that secures the SSD.
  7. Eluktronics N850HK SSD Replacement: étape 7, image 1 de 3 Eluktronics N850HK SSD Replacement: étape 7, image 2 de 3 Eluktronics N850HK SSD Replacement: étape 7, image 3 de 3
    • Reassemble by following the directions in reverse order.
Alternative models where this guide may still apply:
  • Eluktronics N857HK1
  • Eluktronics N850HP6
4 autres ont terminé cette réparation.
Brandon Yuan
Membre depuis le 06/22/24
226 Réputation
1 tutoriel rédigé
Équipe
Austin Community College, Team 6-12, Watkins Summer 2024 Membre de l'équipe Austin Community College, Team 6-12, Watkins Summer 2024
AUSTINCC-WATKINS-SU24S6G12
1 membre
4 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 9
7 derniers jours : 81
30 derniers jours : 363
Total : 4,308
