Introduction
This replacement should take approximately an hour and a half (replacement time may vary). This guide details how to replace the tablet's motherboard by detaching and removing the motherboard after separating the motherboard from the other parts of the tablet.
Ce dont vous avez besoin
Remove back of Ematic FunTab by using the plastic opening tool to pry the back open.
Remove wires:
Start by removing the black wire on each side.
Next, remove the WiFi antenna wire from the motherboard.
Finally, remove the yellow, red, and black wires.
To put the wires back in their correct locations you will need a soldering iron to solder the wire back in place. You will do this once the motherboard is replaced. Here is a guide on how to solder Comment souder et dessouder des connexions
