Aller au contenu principal
Ematic Genesis 2 Audio Jack Repair
Ce dont vous avez besoin
  1. Ematic Genesis 2 Audio Jack Repair, Ematic Genesis 2 Audio Jack Repair: étape 1, image 1 de 2 Ematic Genesis 2 Audio Jack Repair, Ematic Genesis 2 Audio Jack Repair: étape 1, image 2 de 2
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
  2. Ematic Genesis 2 Audio Jack Repair: étape 2, image 1 de 3 Ematic Genesis 2 Audio Jack Repair: étape 2, image 2 de 3 Ematic Genesis 2 Audio Jack Repair: étape 2, image 3 de 3
    • Remove all four screws surrounding the battery with the screwdriver.
    • Carefully remove the battery from the device using the Metal Spudger tool to gently separate the battery by wedging it between the device and the battery.
  3. Ematic Genesis 2 Audio Jack Repair: étape 3, image 1 de 1
    • Remove the two screws that hold the audio jack in place. Carefully lift the audio jack out of the compartment.
    • Use compressed air or a Q-tip to gently clear out the dirt from the inside of the audio jack. This will help make sure future connections are clear.
Taylor Beauchemin
Membre depuis le 08/26/15
113 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 162
