Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Enabling TPM on TUF_B450M_PLUS_GAMING Motherboard
  1. Enabling TPM on TUF_B450M_PLUS_GAMING Motherboard, UEFI BIOS Utility: étape 1, image 1 de 1
    • Turn on the computer, press "DELETE" or "F2" key to enter "UEFI BIOS Utility".
  2. Enabling TPM on TUF_B450M_PLUS_GAMING Motherboard, Advanced Mode (F7): étape 2, image 1 de 1
    • Click on the "Advanced Mode(F7)" option or press the shortcut key "F7" to access the "Advanced Mode".
  3. Enabling TPM on TUF_B450M_PLUS_GAMING Motherboard, Advanced Menu: étape 3, image 1 de 1
    • In "Advanced Mode" choose the "Advanced" tab.
  4. Enabling TPM on TUF_B450M_PLUS_GAMING Motherboard, AMD fTPM configuration: étape 4, image 1 de 1
    • In the "Advanced" tab, choose the "AMD fTPM configuration" option.
  5. Enabling TPM on TUF_B450M_PLUS_GAMING Motherboard, Enable AMD fTPM switch: étape 5, image 1 de 1
    • Under 'AMD fTPM switch' or 'TPM Device Selection', change the option from 'Disabled' to 'Enabled', thus enabling the card's TPM.
  6. Enabling TPM on TUF_B450M_PLUS_GAMING Motherboard, Save & reset: étape 6, image 1 de 1
    • After enabling TPM, press "F10" key to save all changes, then click "OK". Okay, now the machine will be restarted with the TPM enabled.
See how it works in practice in the video below:
Notes: For your machine with Windows 11 to recognize the TPM, the "security device support" must be activated in the bios.
10 autres ont terminé cette réparation.
Merci à ces traducteurs :
pt en
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Manuel
Membre depuis le 12/18/22
587 Réputation
1 tutoriel rédigé
6 commentaires de tutoriel
It would seem that the Sabertooth 990 FX with 8 core 220 Watt CPU and 32 Gb of memory and TPM card onboard, isn’t good enough for the TPM Switch to be accepted by the Bios or Win 10 or be aloud to pass to the upgrade stage.. What a rip Asus, this nearly new (a couple of generations (which is a lifetime in computing) won’t accept TPM even though it’s right there??!! WTF? There must be a workaround I’m missing.
Bart Star - Réponse
For your machine (Windows 10 and 11) to recognize the TPM, the "security device support" must be activated in the bios.
Manuel -
Me aparece la misma pantalla que la de la imagen y me pone el mensajito abajo de " Please press DEL or F2 to enter UEFI BIOS settings" Y yo presiono F2 y no me funciona nada osea se queda en el mismo sitio, ya probé a presionar DEL tambien pero no funciona
Alguien podría ayudarme con este problema?
itsfeli 2006 - Réponse
En las placas ASUS, además de las teclas DEL y F2, también puedes intentar presionar F8 justo después de encender el equipo.
Esa tecla normalmente abre el menú de Boot, donde podrás ver todos los dispositivos disponibles para iniciar y también acceder al Setup (BIOS/UEFI).
Manuel -
mir wird die einsellug mit dem tpm garnicht erst angezeigt
Nico Tillmann - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 19
7 derniers jours : 121
30 derniers jours : 646
Total : 15,213
