Introduction
The lower housing is very important to your Enabot EBO SE since this is where the daughterboard, battery, and speaker are located. You will potentially need to replace them for your Enabot EBO SE to continue functioning correctly. We will take you step by step to replace these necessities and hopefully help you have a more pleasant experience.
Ce dont vous avez besoin
Gently turn the robot upside down.
Place the robot on a stable surface to prevent it from rolling or falling.
Use a Torx screwdriver to remove the four 9 mm screws from the assembly.
