Introduction
The motherboard is essential to the Enabot EBO SE because without it, nothing will function properly. Damages to the motherboard can lead to drastic results in the product's function. In this guide, we will show you how to access and replace your motherboard as smoothly as possible.
Ce dont vous avez besoin
Gently turn the robot upside down.
Place the robot on a stable surface to prevent it from rolling or falling.
Use a Torx screwdriver to remove the four 9 mm screws from the assembly.
Use the iFixit opening tool to unlock the side gray tab and free the orange & black ribbon cable.
Select one of the release tabs on the edge of the upper casing that holds the motherboard in place.
Place one finger in between the motherboard and the upper casing.
Pull the release tab back while lifting the motherboard with your other finger to "pop" the motherboard out of the casing.
