Introduction
Disassemble the engine brake (allows the operator to slow or stop the engine) in order to replace the return spring, bolts, brackets, or cable.
Pièces
Aucune pièce nécessaire.
Remove the return spring by using needle nose pliers, a screwdriver, or other device. I removed the spring by the end of the front bracket (away from the mower handle). Lift up and away from the bracket, and the spring should come out.
  • Remove the return spring by using needle nose pliers, a screwdriver, or other device. I removed the spring by the end of the front bracket (away from the mower handle). Lift up and away from the bracket, and the spring should come out.
  • Beware! The spring is very strong and injury could result if proper care is not exercised.
  • Remove the two bolts using a 7/16 socket.
Ajouter un commentaire
Push the metal tab closest to the black wire down
  • Push the metal tab closest to the black wire down
  • While pushing the tab down, pull the black wire out of the clip.
  • Disassembly is complete!
Jacob Micallef
Membre depuis le 06/03/2017
722 Réputation
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 15
