Introduction
Use the guide to help you replace the battery in your in a Envizen V100M.
Ce dont vous avez besoin
Remove the two screws on the side of the tablet that hold the back cover in place using the ifixit PH00 screwdriver.
The two screws for the back cover are: 1.5mm diameter x 3.5mm long
Remove the non-conductive tape located on the battery and motherboard assembly.
Outil utilisé dans cette étape :Tweezers$4.99
Remove the solder from the red and black wires from the battery attached to the motherboard. Here is a guide on how to solder.
Remove the red and black wire from the motherboard using tweezers. If tweezers are unable to remove the wires, heat can be used to loosen the solder allowing for the wires to be removed.
