Aller au contenu principal
Epiphone ES-335 PRO Tuner Replacement
Ce dont vous avez besoin
  1. Epiphone ES-335 PRO Tuner Replacement, Strings: étape 1, image 1 de 2 Epiphone ES-335 PRO Tuner Replacement, Strings: étape 1, image 2 de 2
    • Using the tuner, loosen the string by turning the tuner.
    • Continue to loosen the string until it is easily unwrapped and pulled out of the tuner.
  2. Epiphone ES-335 PRO Tuner Replacement: étape 2, image 1 de 1
    • On the bridge of the guitar, push the string through the back until the other end is visible. Then grasp and pull the string all the way out.
  3. Epiphone ES-335 PRO Tuner Replacement, Tuner: étape 3, image 1 de 1
    • Using a phillips head #2 screwdriver, unscrew the two 1.0 mm length screws on the sides of the tuner.
    • Be sure to keep track of the screws if you are using them for the new tuner, unless the new tuner has screws of its own.
  4. Epiphone ES-335 PRO Tuner Replacement: étape 4, image 1 de 1
    • The tuner should come right out of the back of the head of the guitar.
Michaih Ley Bayani
Membre depuis le 03/28/18
515 Réputation
4 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 8
30 derniers jours : 11
Total : 1,348
