Aller au contenu principal
Epson EX90 Cooling Fan Replacement
Ce dont vous avez besoin
  1. Epson EX90 Cooling Fan Replacement, Cooling Fan: étape 1, image 1 de 2 Epson EX90 Cooling Fan Replacement, Cooling Fan: étape 1, image 2 de 2
    • Place the projector so that the bottom side is facing upwards
    • Remove the eight screws pictured from the bottom of the device.
    • Open the cover.
    • Be careful when opening the cover; a ribbon cable is still connecting the cover to the motherboard.
  2. Epson EX90 Cooling Fan Replacement: étape 2, image 1 de 1
    • Carefully remove the two parallel wire connectors which connect the fan to the corner of the motherboard.
    • Take care to record the port which each wire comes from, so as not to get your wires crossed.
  3. Epson EX90 Cooling Fan Replacement: étape 3, image 1 de 1
    • Remove the three screws pictured, which hold the fan's frame in place.
  4. Epson EX90 Cooling Fan Replacement: étape 4, image 1 de 2 Epson EX90 Cooling Fan Replacement: étape 4, image 2 de 2
    • Remove fan and related assembly from projector.
    • Detach fan from housing.
    • If the fan is still in good condition, use a paper towel or cloth and clean out all the dust on your fan before reassembling.
Lucas Ketchie
Membre depuis le 04/01/22
160 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 2-3, Mellen Spring 2022 Membre de l'équipe UMass Dartmouth, Team 2-3, Mellen Spring 2022
UMASSD-MELLEN-S22S2G3
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 13
Total : 137
