Introduction
Fans are a mechanical component subject to wear and tear. Mechanical components are often the first to fail. In the event the exhaust fan within the projector begins to emit unpleasant noises, the exhaust fan may need to be replaced.
It is located inside the projector on the same row as the projector lens, all the way to the left, next to the power supply.
Ce dont vous avez besoin
Orient the Epson Home Cinema 2150 so that the large indented panel faces your direction.
Unscrew the single 6mm Phillips#2 holding screw from the access panel.
Slide the panel horizontally, then lift up to remove the access panel.
Remove the air filter cover. Grip the piece with two fingers above and below at the center.
Grab the air filter from the protruding tab and pull the filter out.
Pull up on the rear panel retaining clip.
Pull the rear panel away from the device to remove.
Remove two 6 mm Phillips #1 screws.
Remove two 5 mm Phillips #1 screws.
