Aller au contenu principal
Epson PPC650 Screen Replacement
Ce dont vous avez besoin
  1. Epson PPC650 Screen Replacement, Case: étape 1, image 1 de 3 Epson PPC650 Screen Replacement, Case: étape 1, image 2 de 3 Epson PPC650 Screen Replacement, Case: étape 1, image 3 de 3
    • Make sure the camera is turned off here.
    • Remove batteries from the battery compartment located on the bottom of the camera
    • Remove SD card for the card reader compartment located on the flat side (left side) of the camera
  2. Epson PPC650 Screen Replacement: étape 2, image 1 de 1
    • Remove 2 screws on the rounded side of the camera wisdom here.
  3. Epson PPC650 Screen Replacement: étape 3, image 1 de 2 Epson PPC650 Screen Replacement: étape 3, image 2 de 2
    • Remove 3 screws on the flat side of the camera
    • All silver screws go into the side of the camera that is silver
    • All black screws go into the side of the camera that is black
  4. Epson PPC650 Screen Replacement: étape 4, image 1 de 1
    • Remove 4 screws from the bottom of the camera
  5. Epson PPC650 Screen Replacement: étape 5, image 1 de 3 Epson PPC650 Screen Replacement: étape 5, image 2 de 3 Epson PPC650 Screen Replacement: étape 5, image 3 de 3
    • Separate the front and back pieces of the cameras plastic casing using a spudgerm here.
    • WARNING: When pulling the front plastic casing, be careful of the wire that are connected to the aperture control
    • Use minimal force so that the plastic casing does not break
    • When separating the small silver sliding indicator for view/off/playback may fall out
    • The plastic viewing window located on the top of the camera may also become lose and fall out
  6. Epson PPC650 Screen Replacement, Screen: étape 6, image 1 de 3 Epson PPC650 Screen Replacement, Screen: étape 6, image 2 de 3 Epson PPC650 Screen Replacement, Screen: étape 6, image 3 de 3
    • Remove copper sheet from the front paneling and back.
    • You will need to use a spudger to unsolder the copper paneling
    • Use the spudger to separate the back circuit board from the camera
  7. Epson PPC650 Screen Replacement: étape 7, image 1 de 2 Epson PPC650 Screen Replacement: étape 7, image 2 de 2
    • The picture viewing screen is glued to the backing as well as wired in with pink and white wires.
    • Exert minimal force required to pull the screen loose from the camera
    • Remove the pink and white wiring from the internal paneling. These wires are soldered in
    • Remove the orange data hookup cable which feeds into the back circuit board
    • Once all wires have been detached and the old screen has been removed place the new screen into the camera.
    • Insert data hookup into the back of the camera and into the new screen
    • Re-solder the new pink and white wire onto the internal circuit board
Anne
Membre depuis le 02/12/13
101 Réputation
1 tutoriel rédigé
Équipe
Ohio State, Team 1-5, Buehl Spring 2013 Membre de l'équipe Ohio State, Team 1-5, Buehl Spring 2013
OSU-BUEHL-S13S1G5
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 364
