Aller au contenu principal
Epson PowerLite 822 Plus Lamp Replacement
Ce dont vous avez besoin
  1. Epson PowerLite 822 Plus Lamp Replacement, Lamp: étape 1, image 1 de 1
    • If you just used the projector you will want to let it sit for about an hour to cool off.
    • If you have not used the projector within the past few hours you are ready to get to work.
  2. Epson PowerLite 822 Plus Lamp Replacement: étape 2, image 1 de 2 Epson PowerLite 822 Plus Lamp Replacement: étape 2, image 2 de 2
    • Use a Phillips #2 screwdriver to remove the 6 mm screw that holds the lamp cover in place.
  3. Epson PowerLite 822 Plus Lamp Replacement: étape 3, image 1 de 3 Epson PowerLite 822 Plus Lamp Replacement: étape 3, image 2 de 3 Epson PowerLite 822 Plus Lamp Replacement: étape 3, image 3 de 3
    • Apply pressure to the lamp cover, pulling it towards the end of the projector.
    • Pop the lamp cover off, exposing the lamp.
  4. Epson PowerLite 822 Plus Lamp Replacement: étape 4, image 1 de 3 Epson PowerLite 822 Plus Lamp Replacement: étape 4, image 2 de 3 Epson PowerLite 822 Plus Lamp Replacement: étape 4, image 3 de 3
    • There are two 9mm screws which have already been loosened. These screws do not come all the way out.
    • Grip the finger hold and pull it straight out of the projector.
  5. Epson PowerLite 822 Plus Lamp Replacement: étape 5, image 1 de 1
    • After pulling it straight up by the finger hold the lamp will be revealed and ready to be replaced.
Emma Richey
Membre depuis le 03/21/22
915 Réputation
5 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 148
