Aller au contenu principal
Epson PowerLite Home Cinema 1040 Cooling Fan Replacement
Ce dont vous avez besoin
  1. Epson PowerLite Home Cinema 1040 Cooling Fan Replacement, Removing Housing: étape 1, image 1 de 1
    • Turn off the projector and unplug the power cord.
    • Allow the projector lamp to cool down for an hour or more to prevent injury.
  2. Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: étape 2, image 1 de 3 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: étape 2, image 2 de 3 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: étape 2, image 3 de 3
    • Use the Phillips #2 screwdriver to remove the 9 mm screw that secures the lamp cover.
    • Slide off the lamp cover and remove it from the projector.
    • If the lamp is broken, glass fragments may be found when removing the lamp cover. Be careful when removing the lamp cover and when removing the glass.
  3. Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: étape 3, image 1 de 3 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: étape 3, image 2 de 3 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: étape 3, image 3 de 3
    • Use the Phillips #1 (PH1) screwdriver to remove the three 7 mm screws around the perimeter of the lens cover.
  4. Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: étape 4, image 1 de 3 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: étape 4, image 2 de 3 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: étape 4, image 3 de 3
    • Remove the air filter cover.
    • Remove the two PH1 7mm screws from under the air filter cover.
  5. Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: étape 5, image 1 de 3 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: étape 5, image 2 de 3 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: étape 5, image 3 de 3
    • Remove the two black, PH1, 6mm screws.
  6. Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: étape 6, image 1 de 3 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: étape 6, image 2 de 3 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: étape 6, image 3 de 3
    • Flip the projector so the bottom is exposed.
    • Remove seven PH1 7mm screws on the outer rim of the projector.
    • Some screws are located deeper in the housing and a bit extension or longer screwdriver may be required.
  7. Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: étape 7, image 1 de 2 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: étape 7, image 2 de 2
    • Continuing on the bottom, remove the two black, PH1, 6mm screws.
  8. Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: étape 8, image 1 de 2 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: étape 8, image 2 de 2
    • Remove the cover on the backside of the projector where the inputs are located.
  9. Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: étape 9, image 1 de 3 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: étape 9, image 2 de 3 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: étape 9, image 3 de 3
    • Pull the top half of the housing upwards and rest it on the side.
    • Be careful to not pull upwards too hard. The top is still connected by a thin electric strip.
  10. Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: étape 10, image 1 de 3 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: étape 10, image 2 de 3 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: étape 10, image 3 de 3
    • Using your fingernail or another thin wedging tool, disconnect the electronic strip from the motherboard.
    • Remove the top half of the projector housing completely and set it to the side.
  11. Epson PowerLite Home Cinema 1040 Cooling Fan Replacement, Cooling Fan: étape 11, image 1 de 3 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement, Cooling Fan: étape 11, image 2 de 3 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement, Cooling Fan: étape 11, image 3 de 3
    • Use the Phillips #1 to remove the 3 silver 7 mm screws that secure the fan frame.
  12. Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: étape 12, image 1 de 2 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: étape 12, image 2 de 2
    • Remove the fan frame.
  13. Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: étape 13, image 1 de 3 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: étape 13, image 2 de 3 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: étape 13, image 3 de 3
    • Use a Phillips #1 to remove the bottom left 7mm silver screw.
    • Remove the fan from inside the fan housing.
    • The fan will still be connected to the projector with the wires. We will remove those in the next step.
  14. Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: étape 14, image 1 de 3 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: étape 14, image 2 de 3 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: étape 14, image 3 de 3
    • Unhook the fan wires that connect to the motherboard.
    • Separate the fan wiring from the projector.
Connor Didericksen
Membre depuis le 02/09/23
721 Réputation
6 tutoriels rédigés
Équipe
Utah Tech University, Team 1-6, McMurrin Spring 2023 Membre de l'équipe Utah Tech University, Team 1-6, McMurrin Spring 2023
UTAHTECH-MCMURRIN-S23S1G6
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 20
Total : 296
