Aller au contenu principal
Epson PowerLite Home Cinema 1040 Lamp Replacement
Ce dont vous avez besoin
  1. Epson PowerLite Home Cinema 1040 Lamp Replacement, Lamp: étape 1, image 1 de 1
    • Turn off the projector and unplug the power cord.
    • Allow the projector lamp to cool down for an hour or more to prevent injury.
  2. Epson PowerLite Home Cinema 1040 Lamp Replacement: étape 2, image 1 de 2 Epson PowerLite Home Cinema 1040 Lamp Replacement: étape 2, image 2 de 2
    • Use a Phillips #2 screwdriver to remove the 9 mm screw that secures the lamp cover.
    • If the lamp is broken, glass fragments may be found when removing the lamp cover. Be careful when removing the lamp cover and when removing the glass.
  3. Epson PowerLite Home Cinema 1040 Lamp Replacement: étape 3, image 1 de 2 Epson PowerLite Home Cinema 1040 Lamp Replacement: étape 3, image 2 de 2
    • Slide the lamp cover off by sliding out, then up.
  4. Epson PowerLite Home Cinema 1040 Lamp Replacement: étape 4, image 1 de 2 Epson PowerLite Home Cinema 1040 Lamp Replacement: étape 4, image 2 de 2
    • Loosen the 7mm dark gray screws keeping the lamp in place.
    • The screws do not need to be removed. Simply loosening the screws will allow the lamp to slide out.
  5. Epson PowerLite Home Cinema 1040 Lamp Replacement: étape 5, image 1 de 1
    • Grip the lamp by its raised section, and carefully pull the lamp out of the projector to remove it.
    • The lamps contain mercury; consult state laws regarding disposal.
Connor Didericksen
Membre depuis le 02/09/23
721 Réputation
6 tutoriels rédigés
Équipe
Utah Tech University, Team 1-6, McMurrin Spring 2023 Membre de l'équipe Utah Tech University, Team 1-6, McMurrin Spring 2023
UTAHTECH-MCMURRIN-S23S1G6
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 28
Total : 260
