Aller au contenu principal
Epson PowerLite S4 Exhaust Fan Replacement
Ce dont vous avez besoin
  1. Epson PowerLite S4 Exhaust Fan Replacement, Exhaust Fan: étape 1, image 1 de 1
    • With the bottom of the projector facing you, use a Phillips #00 screwdriver to remove the seven screws.
  2. Epson PowerLite S4 Exhaust Fan Replacement: étape 2, image 1 de 1
    • Use a Phillips #00 screwdriver to remove one screw on the backside of the projector.
    • Slide the panel off.
  3. Epson PowerLite S4 Exhaust Fan Replacement: étape 3, image 1 de 1
    • Lift the top frame from the backside of the projector, with care not to damage any connections.
    • Disconnect the two cables from the motherboard.
  4. Epson PowerLite S4 Exhaust Fan Replacement: étape 4, image 1 de 1
    • Use a Phillips #00 screwdriver to remove one screw.
    • Lift the fan and its mount up and out of the projector.
  5. Epson PowerLite S4 Exhaust Fan Replacement: étape 5, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the two screws securing the fan to its housing, then gently pull them apart to separate each piece.
To reassemble your device, follow these instructions in reverse order using the new exhaust fan.
Max Askew
Membre depuis le 03/28/22
221 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 1-1, Petersen Spring 2022 Membre de l'équipe UMass Dartmouth, Team 1-1, Petersen Spring 2022
UMASSD-PETERSEN-S22S1G1
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 196
