Aller au contenu principal
Epson Powerlite Power Supply Replacement
Ce dont vous avez besoin
  1. Epson Powerlite Power Supply Replacement, Motherboard: étape 1, image 1 de 1
    • Flip the projector over.
    • Remove all 8 screws on the bottom of the projector.
  2. Epson Powerlite Power Supply Replacement: étape 2, image 1 de 2 Epson Powerlite Power Supply Replacement: étape 2, image 2 de 2
    • Now, flip the projector back over and pry the top of it open revealing the inside of the projector.
  3. Epson Powerlite Power Supply Replacement: étape 3, image 1 de 2 Epson Powerlite Power Supply Replacement: étape 3, image 2 de 2
    • Use the spudger to disconnect it from the motherboard.
  4. Epson Powerlite Power Supply Replacement: étape 4, image 1 de 2 Epson Powerlite Power Supply Replacement: étape 4, image 2 de 2
    • Using your finger gently move back and forth the JST cable that connects the top to the motherboard.
    • Now completely take off the top of the projector.
  5. Epson Powerlite Power Supply Replacement: étape 5, image 1 de 2 Epson Powerlite Power Supply Replacement: étape 5, image 2 de 2
    • Remove the 3 screws that secure the motherboard in place.
  6. Epson Powerlite Power Supply Replacement: étape 6, image 1 de 3 Epson Powerlite Power Supply Replacement: étape 6, image 2 de 3 Epson Powerlite Power Supply Replacement: étape 6, image 3 de 3
    • Gently move back and forth the 11 JST connectors until they come out.
  7. Epson Powerlite Power Supply Replacement: étape 7, image 1 de 2 Epson Powerlite Power Supply Replacement: étape 7, image 2 de 2
    • With the spudger lift the red plastic tabs from their connectors.
  8. Epson Powerlite Power Supply Replacement: étape 8, image 1 de 3 Epson Powerlite Power Supply Replacement: étape 8, image 2 de 3 Epson Powerlite Power Supply Replacement: étape 8, image 3 de 3
    • Lift the motherboard and disconnect the JST connector underneath.
  9. Epson Powerlite Power Supply Replacement: étape 9, image 1 de 1
    • Now, the motherboard is completely removed from the projector and you are ready to replace it.
  10. Epson Powerlite Power Supply Replacement, Projector Lens: étape 10, image 1 de 3 Epson Powerlite Power Supply Replacement, Projector Lens: étape 10, image 2 de 3 Epson Powerlite Power Supply Replacement, Projector Lens: étape 10, image 3 de 3
    • Unscrew the four 6mm screws that hold together the fan bracket.
  11. Epson Powerlite Power Supply Replacement: étape 11, image 1 de 2 Epson Powerlite Power Supply Replacement: étape 11, image 2 de 2
    • Unscrew the four 6mm screws that secure the projector.
  12. Epson Powerlite Power Supply Replacement: étape 12, image 1 de 2 Epson Powerlite Power Supply Replacement: étape 12, image 2 de 2
    • Pull out the loose projector.
  13. Epson Powerlite Power Supply Replacement, Power Supply: étape 13, image 1 de 2 Epson Powerlite Power Supply Replacement, Power Supply: étape 13, image 2 de 2
    • Remove the power plug attached to the bracket which kept the fan in place by rocking it back and forth and gently pull up when it is loose.
  14. Epson Powerlite Power Supply Replacement: étape 14, image 1 de 1
    • Remove the rest of the bracket which helped keep the exhaust fan in place.
  15. Epson Powerlite Power Supply Replacement: étape 15, image 1 de 3 Epson Powerlite Power Supply Replacement: étape 15, image 2 de 3 Epson Powerlite Power Supply Replacement: étape 15, image 3 de 3
    • Use a Phillips #2 screwdriver to remove the two 6 mm screws that secure the wire guide.
  16. Epson Powerlite Power Supply Replacement: étape 16, image 1 de 3 Epson Powerlite Power Supply Replacement: étape 16, image 2 de 3 Epson Powerlite Power Supply Replacement: étape 16, image 3 de 3
    • Gently lift up the wire guide to remove the wires.
    • Use your fingers to firmly press on the sides of the power plug and lift it upward.
    • You will now be able to remove and replace the power supply.
Emma Richey
Membre depuis le 03/21/22
915 Réputation
5 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 16
Total : 773
