Aller au contenu principal
Epson Powerlite S5 Projection Lamp Replacement
Ce dont vous avez besoin
  1. Epson Powerlite S5 Projection Lamp Replacement, Projection Lamp: étape 1, image 1 de 2 Epson Powerlite S5 Projection Lamp Replacement, Projection Lamp: étape 1, image 2 de 2
    • Make sure the power is off before beginning.
    • Unplug the projector's power cord from the wall.
    • Allow the projection lamp to cool completely before replacing.
  2. Epson Powerlite S5 Projection Lamp Replacement: étape 2, image 1 de 2 Epson Powerlite S5 Projection Lamp Replacement: étape 2, image 2 de 2
    • Using a Phillip's head screwdriver, remove the screw from the back.
  3. Epson Powerlite S5 Projection Lamp Replacement: étape 3, image 1 de 3 Epson Powerlite S5 Projection Lamp Replacement: étape 3, image 2 de 3 Epson Powerlite S5 Projection Lamp Replacement: étape 3, image 3 de 3
    • Slide the cover back.
    • Lift cover to remove.
  4. Epson Powerlite S5 Projection Lamp Replacement: étape 4, image 1 de 3 Epson Powerlite S5 Projection Lamp Replacement: étape 4, image 2 de 3 Epson Powerlite S5 Projection Lamp Replacement: étape 4, image 3 de 3
    • Locate the two screws on either side of the projection lamp.
    • Using a Phillip's head screwdriver, loosen the two screws.
    • The screws only loosen. You don't have to worry about them falling out.
  5. Epson Powerlite S5 Projection Lamp Replacement: étape 5, image 1 de 3 Epson Powerlite S5 Projection Lamp Replacement: étape 5, image 2 de 3 Epson Powerlite S5 Projection Lamp Replacement: étape 5, image 3 de 3
    • Grip the two plastic bars on the top of the old projection lamp.
    • Remove the projection lamp by pulling straight up.
    • If there is any lamp breakage, handle the shards carefully to avoid injury.
Greg Brown
Membre depuis le 10/06/16
121 Réputation
1 tutoriel rédigé
Équipe
University of Memphis, Team 4-2, Baddour Fall 2016 Membre de l'équipe University of Memphis, Team 4-2, Baddour Fall 2016
UM-BADDOUR-F16S4G2
3 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 1,268
