Aller au contenu principal
Equity Alarm Clock 13014 Alarm Replacement
Ce dont vous avez besoin
  1. Equity Alarm Clock 13014 Alarm Replacement, Alarm: étape 1, image 1 de 3 Equity Alarm Clock 13014 Alarm Replacement, Alarm: étape 1, image 2 de 3 Equity Alarm Clock 13014 Alarm Replacement, Alarm: étape 1, image 3 de 3
    • Use a spudger to open and detach the wiring box from the clock. Insert the flat end of the spudger on both sides of the box, gently pry it open and detach it from the clock. Be careful while handling the box and clock to avoid any damage or injury.
  2. Equity Alarm Clock 13014 Alarm Replacement: étape 2, image 1 de 1
    • To remove the box, please use your fingers to gently grasp it and lift it out. Be careful not to apply too much pressure or force that could damage the box .
  3. Equity Alarm Clock 13014 Alarm Replacement: étape 3, image 1 de 2 Equity Alarm Clock 13014 Alarm Replacement: étape 3, image 2 de 2
    • Use a soldering iron to melt the solder on each wire connection to safely remove the wires.
  4. Equity Alarm Clock 13014 Alarm Replacement: étape 4, image 1 de 2 Equity Alarm Clock 13014 Alarm Replacement: étape 4, image 2 de 2
    • To replace the wiring box, use your hand to remove the old one and install a new one in its place.
2 autres ont terminé cette réparation.
Alaa
Membre depuis le 10/27/14
311 Réputation
2 tutoriels rédigés
Équipe
Un commentaire
Is there someone I can send my alarm clock to for fixing? IF so, how much would it cost? I do not have the tools nor the know how to do it. Most likely, the alarm will have to be replaced. The little motor on the inside is not working when it is time for it to go off. It does not move the ringer/clanger. Thanks,
mariacarbonell@comcast.net
Maria Carbonell - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 11
30 derniers jours : 50
Total : 3,279
