Introduction
If your Ersa i-CON Display is broken, use this guide to get your soldering station working again with a new display.
Replacement displays are available from kurtz ersa under the part number 3EBLCD128X64 and Orient Display under the part number AMG12864PR-G-B12WTDW.
Ce dont vous avez besoin
Outil utilisé dans cette étape :Spudger$3.99
Pull off the control knob using a nylon spudger.
Use pliers or a wrench to unscrew the four plastic nuts holding the display in place.
2 autres ont terminé cette réparation.
