Aller au contenu principal
Etekcity Lasergrip 1080 Laser Replacement
Ce dont vous avez besoin
  1. Etekcity Lasergrip 1080 Laser Replacement, Battery: étape 1, image 1 de 1
    • Pull the battery cover away from the handle by gripping near the thumb groove.
  2. Etekcity Lasergrip 1080 Laser Replacement: étape 2, image 1 de 1
    • Gently pull the battery out of the handle.
    • Excessive force could damage wires.
  3. Etekcity Lasergrip 1080 Laser Replacement: étape 3, image 1 de 2 Etekcity Lasergrip 1080 Laser Replacement: étape 3, image 2 de 2
    • Disconnect the battery by pulling the connector away from it.
    • Positive first
    • Negative second
    • When replacing the battery, this order is reversed.
  4. Etekcity Lasergrip 1080 Laser Replacement, Buttons: étape 4, image 1 de 2 Etekcity Lasergrip 1080 Laser Replacement, Buttons: étape 4, image 2 de 2
    • Remove the battery cover from the device by pulling it straight out.
  5. Etekcity Lasergrip 1080 Laser Replacement: étape 5, image 1 de 2 Etekcity Lasergrip 1080 Laser Replacement: étape 5, image 2 de 2
    • Using the plastic opening tool remove the front and rear yellow covers.
    • When removing the back cover, be careful not to lose the buttons as they are not connected.
  6. Etekcity Lasergrip 1080 Laser Replacement: étape 6, image 1 de 1
    • Remove the two 3.1 mm Phillips #0 screws.
  7. Etekcity Lasergrip 1080 Laser Replacement: étape 7, image 1 de 2 Etekcity Lasergrip 1080 Laser Replacement: étape 7, image 2 de 2
    • Pull the two halves apart.
    • Be careful not to lose any components on the inside.
  8. Etekcity Lasergrip 1080 Laser Replacement: étape 8, image 1 de 1
    • Realign the buttons with the button terminals.
    • Red terminal to red button.
    • Orange terminal to orange button.
    • Yellow terminal to yellow button.
  9. Etekcity Lasergrip 1080 Laser Replacement, Etekcity Lasergrip 1080 Trigger Replacement: étape 9, image 1 de 2 Etekcity Lasergrip 1080 Laser Replacement, Etekcity Lasergrip 1080 Trigger Replacement: étape 9, image 2 de 2
    • Carefully pull the trigger out.
    • The trigger is spring loaded, so be careful that you do not lose the spring as you pull the trigger out.
    • To put the trigger back in, align the peg with the hole in the handle and align the shaft with the button terminal.
  10. Etekcity Lasergrip 1080 Laser Replacement, Laser: étape 10, image 1 de 1
    • Pull the motherboard out of its slot in the device.
  11. Etekcity Lasergrip 1080 Laser Replacement: étape 11, image 1 de 1
    • Use a soldering iron to melt the solder that holds the wires for the laser to the motherboard.
    • Soldering irons are hot and should only be handled by those who know what they are doing and are wearing proper safety equipment. There is a link to a soldering guide in the Troubleshooting section of the device page.
Patrick Crawford
Membre depuis le 08/26/15
741 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team 5-1, Blackwell Fall 2015 Membre de l'équipe USF Tampa, Team 5-1, Blackwell Fall 2015
USFT-BLACKWELL-F15S5G1
3 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 13
Total : 929
