Introduction
While unlikely, your FM antenna may become damaged at some point. If it is, you'll either hear background noise or suffer a loss of signal entirely. In such a case you may need to replace the antenna to bring it to working order.
Ce dont vous avez besoin
Pull the plastic tab on the battery compartment cover panel to loosen it, then pull the panel off.
On the bottom of the device case's face are two T10 screws. Use a T10 Torx screwdriver to remove the two screws.
Remove the Philips #1 screw, securing the FM radio antenna to the case.
To reassemble your device, follow these instructions in the reverse order.
3 commentaires
I bought 2 of these overpriced made in China crap and antenna broke off easily on both. Truly disappointed . Want to replace them with better heavy duty antenna. What brand and model and company do you recommend U buy the antennas from?
where can I get the antenna?
