Aller au contenu principal
Eton FRX3 Rechargeable Battery Pack Replacement
  1. Eton FRX3 Rechargeable Battery Pack Replacement, Rechargeable Battery Pack: étape 1, image 1 de 1
    • Pull the plastic tab on the battery compartment cover panel to loosen it, then pull the panel off.
  2. Eton FRX3 Rechargeable Battery Pack Replacement: étape 2, image 1 de 1
    • Disconnect the battery pack wires from the device and remove the battery pack.
To reassemble your device, follow these instructions in the reverse order.
3 autres ont terminé cette réparation.
Kenneth Sills
Membre depuis le 02/10/16
762 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team 1-6, Nance Spring 2016 Membre de l'équipe USF Tampa, Team 1-6, Nance Spring 2016
USFT-NANCE-S16S1G6
4 membres
13 tutoriels rédigés
4 commentaires
My question is where can you find an FRX3 replacement battery?
jalwitt - Réponse
Hey mate, you can buy the battery packs from a number of sources. Here's the link to one of those sources https://www.amazon.com/HQRP-FR200-BAT-3A...
james -
is it ok to replace it with a higher capacity lithium battery?
troydeleon - Réponse
As long as the specifications match, that should be fine. Just be careful when swapping out components in circuits, as it can potentially destroy the device if they're incompatible!
Kenneth Sills -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 44
Total : 5,421
