Introduction
Instructions for updating the PanelDue firmware can also be found here
Download the latest stable firmware from the Duet Github and extract the zip file
Make sure you download the correct version. The PanelDue 5i and 7i both use the same firmware binary. The file you want is named "PanelDue-5.0i-7.0i.bin"
You need to install "PanelDueFirmware-v3-7.0.zip" or "PanelDueFirmware-v3-5.0.zip"
Download and install Bossa
Hold the erase button on the back of the PanelDue
Connect a USB Micro cable from your PC to your PanelDue. Release the erase button and press the reset button.
Identify the COM port the PanelDue is using.
Click Start->Control Panel->System->Device Manager. Expand Ports (COM and LPT)
Once connected open Bossa.
Select the port in the dropdown. Click Browse and select the PanelDue firmware
Select the checkboxes for Erase all, Lock, and Boot from flash
Click Write. Bossa will load the firmware to the PanelDue. Once upload is complete, click Verify.
8 autres ont terminé cette réparation.
